ethan-rosenberg2822 avatar image
ethan-rosenberg2822 asked mike answered
Fax: How to troubleshoot failed faxes
Problem sending faxes in the US
topic-default
mike avatar image
mike answered
There are a variety of things that can cause a fax to fail, most of which can be resolved by checking  the items listed on this page:  Fax Troubleshooting Checklist
If you have any followup questions you are welcome to post them here.
If you've tried all options and are still having trouble, there is a chance that the receiving fax machine is not compatible with our (and probably other) efax/fax over internet services.
If you need to submit a support case please use the button below, and in the notes include a few samples which include the times, dates of the attempted faxes, plus the numbers you are faxing too, and from.
