Good Afternoon,
The majority of inbound calls are routed through call queues, which are then set to simultaneously ring available users. While reviewing the call log I noticed that the ring events were essentially duplicated, where it showed each user twice. The first result for each user shows the action as "VOIP Call" and the second as "Find Me". You can see this in the attached screenshot.
Ultimately, everything is working (for the most part) as it should be. So, my question isn't prompted by a problem as much as general curiosity. Is this what I should be seeing in the call log? Or is there perhaps a setting or configuration which is incorrect?
