anderson3337 avatar image
anderson3337 asked anderson3337 answered
Replace fax machine...
We are wondering if there is a way to replace the standard fax machine? We know we can send faxes out via email (outbound). But can we utilize RC to do inbound to a fax number? Faxes might come into a mailbox instead of to the machine itself anytime something is sent to that number.
topic-default
cheryl-pelletier3648 avatar image
cheryl-pelletier3648 answered
Yes - this is the only fax machine we use - you can send via email or from the web site - which ever works for you - the emails come into three email addresses so someone sees them no matter what.
mike avatar image
mike answered
Thanks for chiming in Cheryl!!!
To add a little more clarification, with RingCentral you can send or retrieve received faxes via the RingCentral Desktop app which you can install on a Mac or PC,  or you through our web portal.
Let us know if you need more details.
Mike
The desktop app does not work in the Citrix enviroment - we have thin client devices that act as basically a dummie terminal to get employees to the servers which then host our applications.
What are my options?
Chuck Fuscone avatar image
Chuck Fuscone answered
How would you like to receive in bound faxes?  In E-Mail?
What would be the best scenario for you?
Chuck
Certified RC Installer
Yes, that is how it would work.  I usually setup a virtual extension for the fax number, If you have one to port from an analog line then do that first.
This is how I setup all my customers
You fell comfortable with doing this work?
If not let me know
Chuck
Chuck@yoritguy.com
The number porting could be a bit intimidating for some.  Have you ported numbers before?  I would start by porting that analog fax number over to RC, then once it is there, associate it with the new Virtual extension you create for Faxing
You create a user without a phone (This is also called a virtual extension) assign password ETC and get it all set, then turn off things like on hold music , screening, voice mail ETC, as these things are not needed for a fax line.
Then in the notifications section put the E-mail address you want the faxes to arrive at
Should be that simple
Chuck
Chuck@yoritguy.com
The porting process gets initiated through RC  No need to talk to existing carrier (Sprint)
You just need a current phone bill from them as you have to upload it I think as part of the process.
Make sure all spellings are correct in name and address as the slightest thing could delay a port
Chuck
Yes, probably email. So if someone faxes something to that accounting fax number, it would instead get re-routed to email. Or if there is something else we can do to eliminate evening paying for that analog line and utilize RC?
No you could do that now and test with the existing fax number on your account.
This way everything is working and when he number ports you are done.
Chuck
Ok. Did that I believe. I have a unassigned extension with a local number now on my admin account.
