stewart-ross3490 avatar image
stewart-ross3490 asked stewart-ross3490 answered
RC Meeting Presentation Paused - Unable to un pause
Hello
We did our 1st 'Big Screen' RC Meeting on Monday however the presenter had a screen share up with a power point on it.  It was stuck on 'Paused' however and we couldn't get this off.  The users who were then on the call were unable to see past the 1st slide.
Is this something I have done wrong as I was unable to get the presentation off this paused option?
Stewart
topic-default
matt-mikolajczyk2801 avatar image
matt-mikolajczyk2801 answered
Usually if anything happens with screen sharing, most times you can stop the screen sharing all together(not the meeting) and then setup screen sharing for your application again.
mike avatar image
mike answered
Hi Stewart,  I agree with Matt.  First try stopping and restarting the screenshare.  If the issue keeps reoccurring, then you'll probably want to open a support case so the issue can be investigated.
Ok fair enough.  Will try that.  Thanks!
