kristi-debaun4355 avatar image
kristi-debaun4355 asked ace4259 answered
default area code
My default area code shows correctly on the home screen.  however, when I make a local call the area code 706 tags on to the number and call a number in GA.  what can be done?
topic-default
cglassy3135 avatar image
cglassy3135 answered
When logged in as an ADMIN:   This is a setting you can change via the WEB PORTAL if you have access to the PHONES tab on the right side of the screen fill in the corrected default area code for your region and click SAVE. - you just
kristi-debaun4355 answered
Thank you for your response.  I have checked this setting and it is set correctly.  It's almost like it is a setting in the phone itself, but I can't find where to change it.  We are using Cisco SPA942
mike avatar image
mike answered
Kristi,  I've created case 05443632 for you and one of our support agents will be looking into this for you.
Mike
ace4259 avatar image
ace4259 answered
Hi Kristi,
Thanks for reaching out to us. Since this phone is manually provisioned, any settings from the web portal will not take effect on the phone. We don't have this particular model, and newer Cisco models have a different graphical user interface (GUI), so the steps below may not be exactly for the SPA 942. Please try the steps below and let us know if it works or not:
1) Access the GUI of the phone as admin
2) Click on Voice Tab
3) Look for Phone Dial Plan
4) Cut and paste the contents of Phone Dial Plan in notepad (for safekeeping)
5) Copy and Paste the text below:
( *8x 8x[1-9]x. 85xxxxxx *69 *86 *37 *8xx *0x S2 x. #x S2 x. 1 [2-9]xx [2-9]xxxxxx <:1706> [2-9]xxxxxx <:1> [2-9]xx[2-9]xxxxxx [0-9]xxxx 011 xxxxx x. 911 933 611 411 )
6) Click on the submit button
Please let me know of this doesn't work.
Ace
