So we just moved completely over to Ringcentral and thought this was working when we did our testing.
Does Ringcentral show the extensions status correctly on the Polycom VVX series BLF buttons?
Currently ours show if the line is ringing or in call, but if the extension is marked busy or DND it still shows available on the Polycom.
A secondary issue is, does Ringcentral support setting the extensions status to DND when the phones DND button is pressed?
Currently the DND button on the phone simply rejects calls but does not mark the status properly?
These two issues are causing significant problems as no one can reliably and consistently keep their presence info up to date and this worked fine with our old system.
