When installing, and
especially when upgrading to a new release, the Ring Central Desktop software should
not set the RC Fax as the default printer.
I understand you guys are proud of the work you do, but almost nobody sends faxes these days, and RC Desktop should not be so aggressive in setting itself up as the default printer. I have seen this twice now, first when I initially installed the software, and then again when an update came out and I installed that. From a user perspective it makes no sense as I'm am almost never going to send a fax, so I never want it as default. It should be available when I need it, but otherwise should not change my settings.
