rob-jensen4993 avatar image
rob-jensen4993 asked saadetswift16514 answered
extensions not working
Extensions are not always going to the correct person. e.g. Someone types in a persons name and it goes to the conference phone. This happens all the time. What is causing this? Is there a fix?
topic-default
mike avatar image
mike answered
This sounds like an issue with the call handling and forwarding configuration, or perhaps you have an advanced rule set up.  If you are unable to locate the issue,  reply back here with some specifics, time, date, phone numbers/users. etc so we can see a sample.  I'm chainging this to a private conversation so you can post details.
Mike
saadetswift16514 avatar image
Hello Rob,
Are you still experiencing this occurrence?
