stewart-ross3490 avatar image
stewart-ross3490 asked saadetswift16514 answered
Can you have more than 1 Fax number?
Hello
We have a UK fax number setup in the system, however as we are now moving more internationally is it possible to have a 2nd fax number setup in the system as I require a French based fax number added?
topic-default
bjsvec avatar image
bjsvec answered
Yes, I don't see why not.  Did you try?  I think you can just add a number and flag it for fax only or if for a physical fax use an ATA.
saadetswift16514 avatar image
Hello Stewart,
It may be a little bit different for international numbers, but in the US you can purchase another number and change it to be a fax only number. I would verify with your account manager if that can be done with a French number :)
