You can create a template for all users and apply it to them. Below are the instructions!
1) In the Admin Portal select the Users tab and then select Templates
2) Select Add Template and give it a descriptive name
3) Select the User Hour section, toggle on the Override User Settings option, and customize the hours
You can also always apply a template from within the Users Extension
1) Under User Details select the Apply Template button towards the bottom
2) A separate screen will pop up. Choose the desired Template and select the Apply Template button
Want to learn more? Check out and follow our Tip of the Week Index
4) Save your settings
5) On the right-hand side click the Apply button. A separate window will pop up and you will select the users you wish to be affected
