atwood-clerk5603 avatar image
atwood-clerk5603 asked saadetswift16514 answered
No answer-IVR
I would like to be able to have a non-answered call go to an IVR as opposed to voicemail.  how can this be accomplished?  To clarify,  I want EXT 201 to go to IVR 1001 if there is no answer, instead of the voicemail.
topic-default
saadetswift16514 avatar image
Hello Atwood Clerk,
Could you provide an example of how you would expect the call to flow?
For instance, call comes into a user's extension and instead of leaving a voicemail on the extension it goes to an IVR.
I want to get a better understanding so that I can answer your question. Thanks!
