If you use your personal RingCentral Meeting ID and would like to customize it, heres how!
1) Open up your RingCentral Meetings Application and Login
2) Select the Meetings option
3) Select the Edit button below your Personal Meeting ID
4) Select the Change button5) Type in your new number and select Apply
Note: There is also another shortcut that will get you to the same menu as mentioned above
Want to learn more? Check out and follow our Tip of the Week Index
