pak avatar image
pak asked saadetswift16514 answered
Sort Call Recording per extension
 TSR said I can check the recordings per extension by logging in to the user account.  I want the admin portal to have the ability to sort call recordings (call log) per extension.
call logcall recording
saadetswift16514 avatar image
Hello PAK,
You can sort your call log via the extension and call recordings:
1) In the Admin Portal go to the Call Log Tab
2) Select which date option you'd like
3) Then click on the Open Advanced Features arrow
4) From here you can choose which extension you would like to have the call log display and you can check mark the Call Recording box
5) After you've selected your desired settings, always make sure to hit the Show button in order for the results to populate
