January Tidbits
SMS Questions Answered
You've got SMS questions; We've got Answers!
jamesodonnell90 avatar image
jamesodonnell90 asked John Wang commented
PHP cURL not getting a response...
Hi, I'm really having some trouble getting started with this api... I've written the following to get an auth token but I'm getting nothing back in response from the server at all, not even an error am I missing something?
<?php
ini_set('display_errors', 'On'); error_reporting(E_ALL); $headers = array(); $headers[] = 'Authorization: Basic TOKEN'; $headers[] = 'Content-Type: application/x-www-form-urlencoded;charset=UTF-8'; $service_url = 'https://platform.ringcentral.com/restapi/oauth/token'; $curl = curl_init($service_url); $curl_post_data = array( 'grant_type' => 'password', 'username' => 'username', 'extension' => 'ext', 'password' => 'password', ); curl_setopt($curl, CURLOPT_RETURNTRANSFER, true); curl_setopt($curl, CURLOPT_POST, true); curl_setopt($curl, CURLOPT_HTTPHEADER, $headers); curl_setopt($curl, CURLOPT_POSTFIELDS, $curl_post_data); $curl_response = curl_exec($curl); curl_close($curl); $resp = $curl_response; print_r($resp); ?>
James
topic-default
benjamin-dean avatar image
benjamin-dean answered John Wang commented
Have you tried using our PHP SDK? https://github.com/ringcentral/ringcentral-php
John Wang avatar image John Wang ♦♦ commented ·
James,
Please consider the official RingCentral PHP SDK posted by Benjamin:
If you cannot use the official SDK for some reason, you can lift the cURL code from the authCall function here:
