Specifically, I want the
call result field associated with a Task to show a custom call disposition value (ie - No Answer, Left Voicemail, Set a meeting, Not Interested, etc).
I've created a flow that passes the call disposition value to the call result field, but it seems to get overwritten by some line of code. It will also show "Disconnected" even though the call was connected. I tested this using several different users' views.
