hamoody-abdulla1771 avatar image
hamoody-abdulla1771 asked hamoody-abdulla1771 answered
PubNub Subscription Connection - Amazon AWS calls?
In our environment, we have a Palo Alto firewall that monitors traffic to determine which internet circuit to send traffic out of. For example, all voice traffic and ringcentral traffic is set to go out a specific circuit and all internet browsing goes out another. My problem arises when my app tries to subscribe while this advanced policy based forwarding is turned on. What happens is that call to subscribe to the events happens, it goes out internet connection A, but the SDK makes a call to Amazon AWS for some reason, and that traffic goes out connection B. The mismatch on circuits causes the subscription to error out with: " The underlying connection was closed."
How I can fix this problem is by telling the firewall to route all of theses requests to go out the same circuit/internet connection. The problem is, I do not have a list of DNS addresses that it is looking for and the IP changes for Amazon AWS. Is there a way someone can tell me what DNS addresses or what IP range the app is connecting to so that I can make theses changes on my firewall?
I have tested the app with policy based forwarding turned off, forcing all traffic to go out one connection, the subscription works fine and as expected.
This may seem confusing, if you need clarification on something let me know.
topic-default
benjamin-dean avatar image
benjamin-dean answered
Which SDK are you using please? Have you registered this as an issue on the respective Github repository for the aforementioned SDK?
I had to reach out to PubNub support for a IP whitelist and that has solved this issue.
Thanks for letting us know what the blocking issue was and how you solved it.
