dave-welch avatar image
dave-welch asked Anirban Sen Chowdhary answered
I need to change the permissions on a production account. How can I do that?
The permission that we have on the existing account is only RingOut.  We need to run the active-calls method and need the permission(s) for that.  I do not know what those permissions should be or who to contact.  I can always go to our Sales Rep if required but I thought there may be an "Official" way to get this done.
topic-default
benjamin-dean avatar image
benjamin-dean answered
TL;DR Create a new app and re-apply for production.
When you change permissions for your application, you will need to re-apply for production access with the modified sandbox tests (similar to what you originally did to receive production access) and we will review in our weekly production access meeting on Thursdays at 12pm Pacific.
matt2240 avatar image
matt2240 answered
How do we re-apply for production access. The permissions are un-editable. Do we have to create a whole new app?
Anirban Sen Chowdhary avatar image
As per the link below it's mentioned "
You have to clone the app and add new permissions. Then test your app in the sandbox to make sure it uses all the new and old permissions and meet the max error rate requirement."
Ref:- https://forums.developers.ringcentral.com/questions/1511/how-add-permission-after-completion-of-production.html
However, as per I know once your app is in production, you cannot change anything.
You need to ask devsupport@ringcentral.com for any help. Once they added the permission with your request(not sure if they do.. most probably they don't) you need to test again for that permission you acquired.
The official recommendation is to create a new app, add proper permissions and graduate it. So in that case you need to go through again.
