tt2 avatar image
tt2 asked benjamin-dean answered
How to get caller info (caller ID and called Nr.) from telephony presence events?
Whenever you want to be able to find out the Caller ID or the number being called during the progress of a call you can use this example:
var subscription = rcsdk.getSubscription();
subscription.on(subscription.events.notification, function(msg) {
       console.log(msg.body.activeCalls[n].from); // activeCalls is array
       console.log(msg.body.activeCalls[n].to);
   .register({
       events: ['/account/~/extension/~/presence?detailedTelephonyState=true'],
   .then(...);
topic-default
shan109 avatar image
shan109 answered
Please can you provide an example as how I can achieve this via PHP/MySQL system.
sunny2393 avatar image
sunny2393 answered
TT
As I can see there is no such rcsdk.getSubscription(); method found in C# sdk . Am i missing something or Please guide me which SDk i have to use
sunny2393 answered
TT
benjamin-dean avatar image
If you are using the C# SDK, it is recommended to ask questions pertaining to it using the Github Issue tracker for the associated repository. In the case of the C# SDK, that is here:  https://github.com/ringcentral/ringcentral-csharp/issues
