yanmei avatar image
yanmei asked yanmei commented
call log request did not work in sand box
same code for call log api, worked last week, this week I tried again, stopped working, return empty.    Active call api works.
Dim URL As New Uri(WebUtility.HtmlEncode(" https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/call-log"))
API_request.Method = "GET"        API_request.Headers("Authorization") = "Bearer " & Acc_Token
        API_request.Accept = "application/json"
+ Me {REST_API.Form1, Text: Form1} REST_API.Form1+ API_request {System.Net.HttpWebRequest} System.Net.HttpWebRequest
- response {System.Net.HttpWebResponse} System.Net.HttpWebResponse
__identity Nothing Object
CharacterSet "UTF-8" String
ConnectionGroupName Nothing String
ContentEncoding "" String
ContentLength -1 Long
ContentType "application/json; charset=UTF-8" String
+ Cookies {System.Net.CookieCollection} System.Net.CookieCollection
+ CoreResponseData {System.Net.CoreResponseData} System.Net.CoreResponseData
+ Headers {Transfer-Encoding: chunked  Connection: keep-alive  RCRequestId: b4403588-97d2-11e6-9a4e-005056bb26b9  RoutingKey: SJC11P01PAS01  Content-Language: en-US  Vary: Accept-Encoding, User-Agent  x-throttling-group: Heavy  X-Rate-Limit-Group: heavy  X-Rate-Limit-Limit: 10  X-Rate-Limit-Remaining: 9  X-Rate-Limit-Window: 60  X-AGW-Host: sjc11-c01-agw13.devtest.ringcentral.com  Content-Type: application/json; charset=UTF-8  Date: Fri, 21 Oct 2016 21:09:50 GMT  Set-Cookie: RCRoutingInfo=B:JjvG963zMhLp2i9ovcWFNFBA3Z0SlO9Db3kZ8SMmxrq2PPC09d0V6DyGF34WxjqZ; Path=/  Server: nginx/1.8.0    } System.Net.WebHeaderCollection
Identity Nothing Object
InternalSetFromCache Write Only Properties are not supported Boolean
InternalSetIsCacheFresh Write Only Properties are not supported Boolean
InternalSetIsMutuallyAuthenticated Write Only Properties are not supported Boolean
IsCacheFresh False Boolean
IsFromCache False Boolean
IsMutuallyAuthenticated False Boolean
IsWebSocketResponse False Boolean
KeepAlive True Boolean
LastModified #10/21/2016 4:10:03 PM# Date
m_Certificate Nothing System.Security.Cryptography.X509Certificates.X509Certificate
m_CharacterSet "UTF-8" String
m_ConnectionGroupName Nothing String
+ m_ConnectStream {System.Net.ConnectStream} System.IO.Stream
m_ContentLength -1 Long
+ m_cookies {System.Net.CookieCollection} System.Net.CookieCollection
+ m_CoreResponseData {System.Net.CoreResponseData} System.Net.CoreResponseData
m_disposed False Boolean
+ m_HttpResponseHeaders {Transfer-Encoding: chunked  Connection: keep-alive  RCRequestId: b4403588-97d2-11e6-9a4e-005056bb26b9  RoutingKey: SJC11P01PAS01  Content-Language: en-US  Vary: Accept-Encoding, User-Agent  x-throttling-group: Heavy  X-Rate-Limit-Group: heavy  X-Rate-Limit-Limit: 10  X-Rate-Limit-Remaining: 9  X-Rate-Limit-Window: 60  X-AGW-Host: sjc11-c01-agw13.devtest.ringcentral.com  Content-Type: application/json; charset=UTF-8  Date: Fri, 21 Oct 2016 21:09:50 GMT  Set-Cookie: RCRoutingInfo=B:JjvG963zMhLp2i9ovcWFNFBA3Z0SlO9Db3kZ8SMmxrq2PPC09d0V6DyGF34WxjqZ; Path=/  Server: nginx/1.8.0    } System.Net.WebHeaderCollection
m_IsCacheFresh False Boolean
m_IsFromCache False Boolean
m_IsMutuallyAuthenticated False Boolean
m_IsVersionHttp11 True Boolean
m_IsWebSocketResponse False Boolean
m_MediaType Nothing String
m_propertiesDisposed False Boolean
m_StatusCode OK {200} System.Net.HttpStatusCode
m_StatusDescription "OK" String
+ m_Uri { https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/call-log} System.Uri
m_UsesProxySemantics False Boolean
+ m_Verb {System.Net.KnownHttpVerb} System.Net.KnownHttpVerb
m_WebSocketConnectionStream Nothing System.IO.Stream
Method "GET" String
+ ProtocolVersion {1.1} System.Version
+ ResponseStream {System.Net.ConnectStream} System.IO.Stream
+ ResponseUri { https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/call-log} System.Uri
Server "nginx/1.8.0" String
SupportsHeaders True Boolean
str_return Nothing String
+ URL { https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/call-log} System.Uri
topic-default
vb avatar image
vb answered yanmei commented
I just tested and there are no problems. Can you try again ?
If it has problems, can you give us more details with full HTTP Request and Response?
3 comments
yanmei avatar image yanmei commented ·
yes, it did have call records. This morning I tried, it worked, I got call log response back and some call log records in my code. I don't know why it did not work last Friday.   any way, from this point, Please ignore it. thanks for help.
I tried it, still didn't work. return length is -1, Request is good because I can get Active Call,  for Any type of Call log, return length is -1 which is empty.
Dim URL As New Uri(WebUtility.HtmlEncode("https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/call-log";))
'Dim URL As New Uri(WebUtility.HtmlEncode("https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/call-log?&dateFrom=2...)
'Dim URL As New Uri(WebUtility.HtmlEncode("https://platform.devtest.ringcentral.com/restapi/v1.0/account/134091004/extension/134091004/call-log... = Voice&phoneNumber = 16503514555"))
benjamin-dean avatar image benjamin-dean commented ·
Does the timeframe for the call logs you're requesting include a period which contains calls?
yanmei avatar image
yanmei answered
Request:
Response:
  _Stream Nothing System.IO.StreamReader
+  e {System.Windows.Forms.MouseEventArgs} System.EventArgs
+  Headers {Transfer-Encoding: chunked  Connection: keep-alive  RCRequestId: 8ae9ca14-97d7-11e6-abc3-005056bb26b9  RoutingKey: SJC11P01PAS01  Content-Language: en-US  Vary: Accept-Encoding, User-Agent  x-throttling-group: Heavy  X-Rate-Limit-Group: heavy  X-Rate-Limit-Limit: 10  X-Rate-Limit-Remaining: 9  X-Rate-Limit-Window: 60  X-AGW-Host: sjc11-c01-agw11.devtest.ringcentral.com  Content-Type: application/json; charset=UTF-8  Date: Fri, 21 Oct 2016 21:44:28 GMT  Set-Cookie: RCRoutingInfo=B:JjvG963zMhLp2i9ovcWFNFBA3Z0SlO9Db3kZ8SMmxrrUKU0aO0VJmtfRX8zygttx; Path=/  Server: nginx/1.8.0    } System.Net.WebHeaderCollection
  LastModified #10/21/2016 4:44:33 PM# Date
+  m_HttpResponseHeaders {Transfer-Encoding: chunked  Connection: keep-alive  RCRequestId: 8ae9ca14-97d7-11e6-abc3-005056bb26b9  RoutingKey: SJC11P01PAS01  Content-Language: en-US  Vary: Accept-Encoding, User-Agent  x-throttling-group: Heavy  X-Rate-Limit-Group: heavy  X-Rate-Limit-Limit: 10  X-Rate-Limit-Remaining: 9  X-Rate-Limit-Window: 60  X-AGW-Host: sjc11-c01-agw11.devtest.ringcentral.com  Content-Type: application/json; charset=UTF-8  Date: Fri, 21 Oct 2016 21:44:28 GMT  Set-Cookie: RCRoutingInfo=B:JjvG963zMhLp2i9ovcWFNFBA3Z0SlO9Db3kZ8SMmxrrUKU0aO0VJmtfRX8zygttx; Path=/  Server: nginx/1.8.0    } System.Net.WebHeaderCollection
  Method "GET" String
+  sender {System.Windows.Forms.Button, Text: Call Log} Object
