ajathar avatar image
ajathar asked benjamin-dean commented
Prod Version Error
Rendering Failed on sending fax to any numbers on production version.
topic-default
benjamin-dean avatar image
benjamin-dean answered
Is this when sending via the API or via the product/soft phone please?
Tyler Liu avatar image
Tyler Liu answered
More information is needed for troubleshooting.
ajathar answered
Iam sending it through the API. and my API is in PRODUCTION. it was working fine in the Sandbox version.
Tyler Liu answered
Could you please post your sample code for sending fax via the API (don't forget to remove your credentials) ?
Does it always fail regardless of the content of the fax? It is helpful if you give me a runnable sample project to reproduce the issue.
ajathar answered
Hi Tyler,
Good Morning.
This is my sample Dot Net Code.
SDK sdk;            var requestBody = JsonConvert.SerializeObject(new
                faxResolution = "High",
                coverIndex = 1,
                coverPageText = "Dummy Test",
                to = new object[] { new { phoneNumber = "123456789" } }
            sdk = new SDK("appkey", "appsecret", " https://platform.ringcentral.com";, "Dispatcher", "1.0.0");
            sdk.Platform.Login("number", "extension", "password", true);
            var attachments = new List<Attachment>();
            var textBytes = System.Text.Encoding.UTF8.GetBytes("hello fax");
            var attachment = new Attachment(@"test.pdf", "application/pdf", textBytes);
            attachments.Add(attachment);
            var request = new Request("/restapi/v1.0/account/~/extension/~/fax", requestBody, attachments);
            var body = request.HttpContent;
            Assert.NotNull(body);
            var response = sdk.Platform.Post(request);
            Assert.AreEqual(true, response.OK);
Yes it always fails even when i change my contents.
Tyler Liu answered
Could you please do me a favor to post a screenshot of the exception you got? Thanks
ajathar answered
Response after sending the fax.
Response by quering the message id
Tyler Liu answered
Sorry for the late reply. But it took me quite a well until I found a possible root cause.
"textBytes" above is plain text, but you tell the server side that it's "application/pdf", that's why server side failed to render it.
I don't think you can get this code work in sandbox. So please try again and tell me whether it works in sandbox.
And Please also try my sample code:
var attachment = new Attachment("test.txt", "text/plain", textBytes);
Or if you want to send a pdf file instead:
var pdfBytes = System.IO.File.ReadAllBytes("test.pdf");
var attachment = new Attachment("test.pdf", "application/pdf", pdfBytes);
And by the way, now we have another C# library which is much more user friendly:  https://github.com/ringcentral/ringcentral-csharp-client
And here is some sample code for sending fax using the new library:  https://github.com/ringcentral/ringcentral-csharp-client/blob/master/RingCentral.Test/FaxTest.cs
ajathar answered benjamin-dean commented
Hi Tyler,
Thanks for the help.Its working now. Just missed that code. :)
benjamin-dean avatar image benjamin-dean commented ·
Glad you are back in business.
