January Tidbits
SMS Questions Answered
You've got SMS questions; We've got Answers!
point-of-rental-software3262 avatar image
point-of-rental-software3262 asked John Wang answered
active-calls for current login user
https://platform.ringcentral.com/restapi/v1.0/account/~/extension/~/active-calls
https://platform.ringcentral.com/restapi/v1.0/account/123456/extension/7020/active-calls
didn't work, nothing returned even extension 7020 is answering the call.
I need current call record to show whom the logged user is talking to. we have more than 60 different extensions.
topic-default
John Wang avatar image
John Wang answered
When you say extension 7020, do you mean 7020 is the extension number that is dialed to reach the user?
If so, then 7020 is what is called the "extensionNumber" in our API which can be used for dialing purposes. However, the number in the REST API path is the "extensionId" which is a different number. To retrieve a list of extensions call the extension (account/{accountId}/extension) endpoint and you will get a list of extensions back with both and "id" (aka "extensionId") property and an "extensionNumber". The "id" property is the one that is used in the REST API path.
