comiere-healthcare1789 avatar image
comiere-healthcare1789 asked travis-carona1490 answered
status 403, [OutboundSMS] permission required
it works in sandbox for sms:
Receipt(status=200, response={  "uri" : " https://platform.devtest.ringcentral.com/restapi/v1.0/account/665152005/extension/665152005/message-...;,  "id" : 2682755004,  "to" : [ {    "phoneNumber" : "+16304235327",    "location" : "Aurora, IL"  } ],  "from" : {    "phoneNumber" : "+13234308604",    "location" : "Montebello, CA"  },  "type" : "SMS",  "creationTime" : "2017-02-13T15:01:47.000Z",  "readStatus" : "Read",  "priority" : "Normal",  "attachments" : [ {    "id" : 2682755004,    "uri" : " https://platform.devtest.ringcentral.com/restapi/v1.0/account/665152005/extension/665152005/message-...;,    "type" : "Text",    "contentType" : "text/plain"  } ],  "direction" : "Outbound",  "availability" : "Alive",  "subject" : "Test SMS using a RingCentral Developer account - test sms content",  "messageStatus" : "Sent",  "smsSendingAttemptsCount" : 1,  "conversationId" : 6361148894337915435,  "conversation" : {    "id" : "6361148894337915435",    "uri" : " https://platform.devtest.ringcentral.com/restapi/v1.0/conversation/6361148894337915435";  },  "lastModifiedTime" : "2017-02-13T15:01:48.059Z"}, key=null)
however it doesn't work in production:
Receipt(status=403, response={  "errorCode" : "FeatureNotAvailable",  "message" : "[OutboundSMS] permission required",  "errors" : [ {    "errorCode" : "CMN-408",    "message" : "[OutboundSMS] permission required",    "permissionName" : "OutboundSMS"  } ],  "permissionName" : "OutboundSMS"}, key=null)
topic-default
benjamin-dean avatar image
benjamin-dean answered
I am conducting some experiments right now to see if I am able to recreate this issue and if I do I will report this issue to our engineering team.
In the meantime, developers should keep in mind that unless the effort to match development (sandbox) accounts to closely match that of live (production) accounts, there are specific steps which should be taken to prevent these types of issues:
When a user first authenticates with your application you should get the account phone number list, and ensure the "features" for any company number you plan on sending an SMS with have "SmsSender" in the list:
https://developers.ringcentral.com/api-docs/latest/index.html#!#RefGetAccountInfo
Before attempting to send an SMS message, you should first verify the following:
1. The Extension has a phone number with the SMS feature enabled https://developers.ringcentral.com/api-docs/latest/index.html#!#RefGetExtensionPhoneNumbers
2. Check the User Permissions to be certain the user has SMS enabled:  https://developers.ringcentral.com/api-docs/latest/index.html#!#RefGetUserPermissions (I WOULD RECOMMEND THIS FOR EVERY DEVELOPER AT ALL TIMES)
I have tested this using my personal sandbox and production account (and the same application), and was unable to recreate the issue you reported.
I would recommend using the links I have provided above to be certain that the account/extension/phone number have SMS enabled as a feature prior to sending the SMS (and if they do not, and your app has a UI component, displaying the appropriate UI to the user for the unhappy path).
comiere-healthcare1789 answered benjamin-dean commented
faxes works for production, but sms doesn't work, most likely SMS is disabled for the production phone number
settings is not editable after applied for production. I don't have ReadAccounts permission, I cannot invoke the get APIs to check if SMS enabled?
may I have the admin or any contact who can solve the issue for me?
benjamin-dean avatar image benjamin-dean commented ·
Please see this community post which addresses your current needs:  https://devcommunity.ringcentral.com/ringcentraldev/topics/how-can-i-add-new-permissions-to-an-app-w...
travis-carona1490 avatar image
Before my SMS was working in production. now I am getting 403 responses, sandbox seems to be ok.
I already have SMS permission enabled.
