matt-wheeler4956 avatar image
matt-wheeler4956 asked bjsvec answered
Connecting via SIP with a TAPI Bridge
Good Morning all.
So, Ive hit a minor road block and Im REALLY hoping the community can assist with this.
I have a legacy CRM application that used to connect to our old Dialer system via TAPI.
Now, Ive searched and before a RC Official Rep says it, yes, I know, TAPI is not supported by Ring Central.
However, SIP is supported...
So, I have found SIPTAPI (Previously referenced https://devcommunity.ringcentral.com/ringcentraldev/topics/how-to-integrate-ringcentral-with-siptapi... and responded to by @Benjamin Dean).
However, its 9mths old and really does not cover anything about how and whether it could/can connect.
In principle, as long as I have SIP Domain, User, Password then all should be fine.
  • SIP Domain: sip.ringcentral.com
  • User: [my phone number]
  • Password: [My Password for RC]
  • Extension: [Optional]
However, it appears as though its trying to connect but getting either rejected from the SIP platform, or hanging for some reason.
Now, one answer might be that SIPTAPI is classed as a SIP device, and has not been authorised/cleared to connect therefore its not gone through testing and as Ive not written it, thats going to clearly be a problem.
It also might be, and the answer Im very much hoping for, is that Ive entered in the wrong information somewhere.
I did read that you log in with your AuthID and Password....but not seen any confirmation.
Can someone please help on this?
Matt
topic-default
lee-d3574 avatar image
lee-d3574 answered
I could be wrong but if it's classified as a SIP Device by RC I would assume it would need to be authorized on the RingCentral side to connect as a device?  So you would need to add a MAC address for it and get an authorization id as if it were a non ringcentral phone?
FIELD
VALUE
SIP Domain
sip.ringcentral.com:5060
Outbound Proxy
sip10.ringcentral.com:5090
User Name
full phone number, starting with 1 then the area code and number
Password
UNbI9BEY assigned by the system, changeable later
Authorization ID
60428140012 assigned by the system
I haven't done this mind you it just seems like the next place to look.
bjsvec avatar image
bjsvec answered
I agree with Lee D, but also don't feel this is the best way to do what you are wanting to do.  It *may* work if you add a third party device and use the info and credentials from the new line though.  See here if you want to try:  https://success.ringcentral.com/articles/RC_Knowledge_Article/4966 it shows where you will get relevant info like:
