evgeny-alhovik5405 avatar image
evgeny-alhovik5405 asked John Wang commented
Cannot authorize with RingCentral C# Client
Cannot authorize via C# Client
sample code below:
 rc = new RestClient(Config.Instance.appKey, Config.Instance.appSecret, false);
 var result = rc.Authorize(Config.Instance.username, Config.Instance.extension, Config.Instance.password).Result;
The error is "Request to https://platform.devtest.ringcentral.com/restapi/oauth/token failed with status code 400 (Bad Request)."
In case I try to use C# SDK, I always get following response error:
  "error" : "invalid_grant",
  "error_description" : "Invalid resource owner credentials."
topic-default
Tyler Liu avatar image
Tyler Liu answered John Wang commented
Please check the password. The error message means your password is invalid.
6 comments
John Wang avatar image John Wang ♦♦ commented ·
There are two types of accounts for development:
Production credentials - this is used for production use
Sandbox (test) credentials - this is for the test environment
When you are accessing anything with "devtest" in the domain, you should use your Sandbox credentials which are provided in the Developer Portal under the Credentials tab as mentioned by Tyler
Tyler Liu avatar image Tyler Liu commented ·
I just tried an invalid password and I got the same error message.
e-z-u-r-s-dot-com5406 avatar image e-z-u-r-s-dot-com5406 commented ·
Am I right to say that same password used to login to  https://developer.ringcentral.com ? I can log in there with my password. Even I can send sms via  API Explorer
One more error message I get when I use C# Client
  "error": "invalid_client",
  "errors": [
      "errorCode": "OAU-153",
      "message": "Invalid client: ",
      "parameters": [
          "parameterName": "client_id",
          "parameterValue": ""
  "error_description": "Invalid client: "
There are two kinds of RingCentral apps: private and public.
Please double check. Is your app public or private? If it's private, only certain users can login. It might be the root cause of the problem.
