tweety5299 avatar image
tweety5299 asked tweety5299 commented
spring REST template to send fax with attachment
Please find below the REST call to the "send fax" api.
Though the fax is being sent, the attachment is not sent.
Can you please help if the request is missing some entity?
byte[] attachment = getBVendorRenewalLetter();
MultiValueMap<String,Object> bodyMap = new LinkedMultiValueMap<String,Object>();
bodyMap.add("file", attachment);
bodyMap.add("to", "test phone number");
bodyMap.add("Authorization", accessToken);
HttpHeaders headers = new HttpHeaders();
headers.setContentType(MediaType.APPLICATION_JSON);
headers.setContentDispositionFormData("content", "testFile.pdf");
headers.add("to", "test phone number");
headers.add("Authorization", accessToken);
HttpEntity<Object> requestEntity = new HttpEntity<Object>(bodyMap, headers);
ResponseEntity<RingCentralResponseDTO> response = restTemplate.exchange(" https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/fax";, HttpMethod.POST, requestEntity, RingCentralResponseDTO.class);
Thank You very much
topic-default
ak avatar image
ak answered tweety5299 commented
Please refer to the below sample in Java to send Fax:
https://github.com/vyshakhbabji/ringcentral-java/blob/master/src/utils/SendFax.java
3 comments
tweety5299 avatar image tweety5299 commented ·
Yes AK. It did. Thank you very much once again. I used the sample code to use the okHttp Client to make the REST call and it works great !
Thank you for the pointer.
ak avatar image ak commented ·
You are welcome Tweety. Did the sample code help ?
