hambrise-alan5624 avatar image
hambrise-alan5624 asked hambrise-luke-alan-j5494 answered
I have created subscription using webhook and i am getting response. i need call record Id in the response.
I have created subscription using webhook and i am getting response as below. i need to fetch call record for this Event how can i do? please help to get it resolved.
  "uuid": "1343368781877007566-7030373935822630719",
  "event": "/restapi/v1.0/account/129965004/extension/129965004/presence?detailedTelephonyState=true",
  "timestamp": "2017-05-22T12:18:50.808Z",
  "subscriptionId": "83efa9c0-710a-4b06-a9fd-949834c7f713",
  "body": {
    "extensionId": 139055004,
    "telephonyStatus": "CallConnected",
    "activeCalls": [
        "id": "PDhBLpqFMHGWlHSsd5foXioTWJVzGT3e",
        "direction": "Outbound",
        "from": "+16603314970",
        "to": "+19158701061",
        "sessionId": "19345726003"
    "sequence": 542039,
    "presenceStatus": "Busy",
    "userStatus": "Available",
    "dndStatus": "TakeAllCalls",
    "allowSeeMyPresence": true,
    "ringOnMonitoredCall": false,
    "pickUpCallsOnHold": false
topic-default
ak avatar image
ak answered
You could use  Call-Log API filtered by ' sessionId' to match the Presence events ( Push notifications ) when you receive using webhooks.
For ex:
You could use the sessionID from the webhook push notifications above ( 19345726003 ) to make an API call to Call - Log endpoint as below:
Request
GET /restapi/v1.0/account/~/extension/~/call-log?sessionId=19345726003
Note: (  ~ ) tilde refers to the extension assigned to the account logged-in within the current session
If you would like to receive the account level call logs kindly use:
/restapi/v1.0/account/~/call-log?sessionId=19345726003
hambrise-luke-alan-j5494 avatar image
SessionID is ok, but for every notification type i am getting same session ID. what shall i do.
ak avatar image
ak answered
The sessionID remains same across the three events if it is for a specific call, for ex:
1.) Ringing
2.) Call Connected
3.) No Call
For all the three notifications on a single call, you would receive the same sessionID for the push notifications.
May I know what is it that you are trying to achieve?
 I though session Id will be same for all calls. thank you i got it.
