pratap-s5689 avatar image
pratap-s5689 asked Tyler Liu commented
GLIP API POST Message not found
Hi ,
I am trying to post message to glip group chat using curl command but I am getting always {"message":"Not Found"}.
I have given Glip permission under  Settings -> Oauth Settings -> Permission Needed
Below is the command which I am using:
curl -H "Content-Type: application/json" -H "Authorization: Bearer $token" -X POST https://platform.devtest.ringcentral.com/restapi/v1.0/glip/posts -d'{ "groupId":"52626304005","text":"Hi there! Test message"}'
topic-default
alexey-sobolev5691 avatar image
alexey-sobolev5691 answered
Hi, Pratap.
Are you sure, that group with id '52626304005' does exists?
Could you, please, provide list of your groups? (GET /restapi/v1.0/glip/groups)
Best regards,
Alexey Sobolev
pratap-s5689 answered
Hi Alexey,
Getting this curl -XGET -i -H "Content-Type: application/json" -H "Authorization: Bearer $token" ' https://platform.devtest.ringcentral....'
HTTP/1.1 404 Not Found
Server: nginx/1.10.2
Date: Fri, 02 Jun 2017 10:43:09 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 23
Connection: keep-alive
ETag: W/"17-5mp6bJHiwmgD8/Sf63qIPw"
X-Server-Name: sjc06-c01-hlb01
X-Request-Time: 0.080
X-Upstream-Server: 10.24.21.167:56314
X-Upstream-Status: 404
X-Upstream-HTime: 0.080
X-Upstream-RTime: 1496400189.474
X-Upstream-CTime: 0.000
X-Tcpinfo: 1000, 500, 10, 28960
X-Rate-Limit-Group: light
X-Rate-Limit-Limit: 50
X-Rate-Limit-Remaining: 49
X-Rate-Limit-Window: 60
RoutingKey: SJC11P01
RCRequestId: 44db02fa-4780-11e7-bf71-005056bb594d
alexey-sobolev5691 answered Tyler Liu commented
Oh, ok.Our API is working only for users already registered in Glip (It's temporary limitation).
So you need to sign up via RC in Glip ( https://glip.devtest.ringcentral.com/). And after that API will start working.
Best regards,
Alexey Sobolev
5 comments
alexey-sobolev5691 avatar image alexey-sobolev5691 commented ·
You need to go to  https://glip.devtest.ringcentral.com/ (It's Glip sandbox). Then you need follow "Sign In" -> "Sign In With Ringcentral". Then you need to authorize in RC (by any method - by phone, by SSO and etc). After that you will be refirected back to Glip. Right after it our API will start working for you.
pratap-s5689 avatar image pratap-s5689 commented ·
Hi Alexey,
I am bit confused here. I have signed up for RIngcentral app and using other features too. Can you exactly let me know which email ID I should use to signup to the URL ( https://glip.devtest.ringcentral.com/)
1st Email id used to signup to Ringcentral I am using this user to get secret and access to generate the token
OR
2nd My User account email id under ringcentral. This user is my user visible within the organisation.
Thanks let me try this.
Tyler Liu avatar image Tyler Liu commented ·
Nope, you cannot. Your devtest credential cannot be used in production.
Thanks Alexey, it worked. I wonder if I can post messages to  https://app.glip.com/ instead of  https://glip.devtest.ringcentral.com/ using my current credential as my account is not yet moved to production.
-1 Like -1 ·
