eugene1578 avatar image
eugene1578 asked Tyler Liu answered
i want to make app using ringcentral
Hi.
i am ringcentral beginer.
i am developing app using the https://github.com/ringcentral/ringcentral-csharp-client c# SDK.
Can i realize softphone using ringcentral c# sdk.?
i have several question.
question is follow.
1.      how to Accept Incoming Call
2.      In order to call, what should i do on code?.
I have realized about ring function at present. But I cant call(send and receive voice).
What do I have to next step?.
In a word, What should I do to go  form ring to connected?
Please explain the step to call.
3.       how to Creates SIP registration of a device/application?
    my ringcentral accout info is as follow.
          phoneNumber. 18059213091
          pass   TempPass1!
         app: ringcentral_DesktopApp
Result to Creates SIP registration  is follow.
o
  Curl
curl -X POST --header "Content-Type: application/json" --header "Accept: application/json" --header "Authorization: Bearer U0pDMTFQMDFQQVMwMHxBQUEzQmFzcU1WVVpjWnNLemg1V0hJMkpGbEExNExWU21Cd0VuVnAweERZc2NubDhlcFhtY2Q1czhVT2dzenlQREkxNF9QWWRPMEVYNENYQjd4dmJsWHJoVHJNQURXT09Va3pUbnJ2enFlcXBkbTN3YjFDdGhGUXpXTDZXUjhrSGhLX3ZIZU5lVDNUUE50cnpRNWM4OEw5OEo1ejc1WmhSNE5PcUVfeHVObHkyNWZpNWxtZWNTRFFwSzc4M2ZYWWtWV0l8MGRybm93fDZCcV9Jc0ZlT0M3d0ZVUkJIUHFOTWc" -d "{\"sipInfo\":{\"transport\":\"WSS\"}}" "https://platform.devtest.ringcentral.com/restapi/v1.0/client-info/sip-provision"
Request URL
Response Body
  "errorCode": "CMN-301",
  "message": "Request rate exceeded",
  "errors": [
Response Code
401
Response Headers
  "date": "Sat, 01 Jul 2017 23:23:37 GMT",
  "content-length": "161",
  "content-language": "en",
  "routingkey": "SJC11P01",
  "content-type": "application/json"
i am sure that you will help me well.
topic-default
Tyler Liu avatar image
Tyler Liu answered
As far as I can tell, it's impossible to implement a working soft phone with merely C#. There is no way to accept a call with C#. There is also no way to make a call directly except Ringout.
If you want to create a soft phone programmatically, you can take a look at webrtc. And here is the library:  https://github.com/ringcentral/ringcentral-web-phone
