dat-le5843 avatar image
dat-le5843 asked Tyler Liu commented
Using RingCentral in web api
I am using the  https://github.com/ringcentral/ringcentral-csharp-client c# SDK.
When I run the code to send a fax through a unit test that is in the same Visual Studio solution as the api call, it works.
var restClient = new RestClient(_appKey, _appSecret, _appUrl);
var token = await rc.Authorize(_appUserName, null, _appPassword).Result;
However, when I wrap this functionality within an C# ApiController, it hangs at this point and I can't get the result.
Is there something special I need to do here?  My RingCentral app is set for Server-only (No UI) as I would only access the RingCentral API through a in-house built Web Api server.
topic-default
dat-le5843 answered
I did find a work-around. I had to bypass the SDK and call API directly to get the TokenInfo
using (var client = new HttpClient())
                client.BaseAddress = new Uri(ConfigurationManager.AppSettings["RingCentralApiUrl"] + "/");
                var credentials = Encoding.ASCII.GetBytes(String.Format("{0}:{1}", _appKey, _appSecret));
                client.DefaultRequestHeaders.Authorization = new AuthenticationHeaderValue("Basic", Convert.ToBase64String(credentials));
                var formContent = new FormUrlEncodedContent(new[]
                    new KeyValuePair<string, string>("username", _appUserName),
                    new KeyValuePair<string, string>("grant_type", "password"),
                    new KeyValuePair<string, string>("access_token_ttl", "3600"),
                    new KeyValuePair<string, string>("refresh_token_ttl", "604800"),
                    new KeyValuePair<string, string>("password", _appPassword)
                var response =
                    client.PostAsync("restapi/oauth/token", formContent).Result;
                if (response.IsSuccessStatusCode)
                    var result = response.Content.ReadAsStringAsync().Result;
                    var token = JsonConvert.DeserializeObject<TokenInfo>(result);
                    rc.token = token;
                    return token;
Tyler Liu avatar image
Tyler Liu answered
C# async is tricky, if you don't do it properly your app will hang.
I will recommend never using ".Result", just stick to "await".
So "var token = await rc.Authorize(_appUserName, null, _appPassword).Result;"
should be "var token = await rc.Authorize(_appUserName, null, _appPassword);"
You are not alone:  https://www.google.com.hk/search?q=C%23+async+hang&oq=C%23+async+hang&aqs=chrome..69i57j69i5...
And this is a C# programming issue instead of a SDK issue.
danilo-meireles6216 avatar image
danilo-meireles6216 answered Tyler Liu commented
Hello!
I've tried different ways to call api from C# but I get (400)BAD REQUEST.
What am I doing wrong here?
Thank you very much!
var appKey = "myAppKey";
var appSecret = "myAppSecret";
var appUrl = " https://platform.devtest.ringcentral.com"
var userName = "+19167582841";
var password = "myPassword";
var restClient = new RestClient(appKey, appSecret, appUrl);
var token = await restClient.Authorize(userName, null, password);
I already tried this as well and get bad request:
            var password = "myAppPassword";
            var uri = " https://platform.devtest.ringcentral.com/restapi/oauth/token";
                client.BaseAddress = new Uri(uri + "/");
                var credentials = Encoding.ASCII.GetBytes(String.Format("{0}:{1}", appKey, appSecret));
                    new KeyValuePair<string, string>("username", userName),
                    new KeyValuePair<string, string>("password", password)
                var response =
                    //rc.token = token;
                    //return token;
Thank you very much!!
Tyler Liu avatar image Tyler Liu commented ·
Could you please create a new ticket instead since this one is old and irrelevant to your question?
And please post the FULL error message, otherwise we don't know what happened.
