fax number avatar image
fax number asked Phong Vu answered
Sending fax with php code, Fax sending without attachments.
<?php
$ch = curl_init();
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($ch, CURLOPT_URL, "https://platform.ringcentral.com/restapi/oauth/token");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, "username=+xxxxxx&password=password#&extension=102&grant_type=password");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_USERPWD, "PYS9kaDdSey5j72ljRCfDw" . ":" . "JV4wWOkJTX5sJf-OZDD_fgJJ-uZODeSPeXxdhMUtsTAN");
$headers = array();
$headers[] = "Accept: application/json";
$headers[] = "Content-Type: application/x-www-form-urlencoded";
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$result = curl_exec($ch);
$results = (json_decode($result));
$token = $results -> access_token;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://platform.ringcentral.com/restapi/v1.0/account/~/extension/~/fax");
curl_setopt($ch, CURLOPT_POST,1);
curl_setopt($ch, CURLOPT_POSTFIELDS, array(
'from' => '+xxxxx',
'to' => '+xxxxxx',
'name'=>'sample.pdf',
'attachments'=> '@'.realpath('sample.pdf'),
'coverpagetext' => 'PHP FaxOut Via cURL'
$headers = array();
$headers[] = "Accept: application/pdf";
$headers[] = "Authorization: Bearer $token";
$headers[] = "Content-Type: multipart/form-data";
$result1 = curl_exec($ch);
print_r($result1);
if (curl_errno($ch)) {
echo 'Error:' . curl_error($ch);
curl_close ($ch);
Response
{ "uri" : "https://platform.ringcentral.com/restapi/v1.0/account/628394008/extension/628447008/message-store/986620102017", "id" : 986620102017, "to" : [ { "phoneNumber" : "+12158600723", "location" : "Newtown, PA", "messageStatus" : "Queued" } ], "type" : "Fax", "creationTime" : "2019-05-29T07:09:48.000Z", "readStatus" : "Unread", "priority" : "Normal", "attachments" : [ { "id" : 986620102017, "uri" : "https://media.ringcentral.com/restapi/v1.0/account/628394008/extension/628447008/message-store/986620102017/content/986620102017", "type" : "RenderedDocument", "contentType" : "application/pdf" } ], "direction" : "Outbound", "availability" : "Alive", "messageStatus" : "Queued", "faxResolution" : "High", "faxPageCount" : 0, "lastModifiedTime" : "2019-05-29T07:09:48.752Z", "coverIndex" : 7 }
php
2 comments
Phong Vu avatar image Phong Vu ♦♦ commented ·
What is your question? Or is that you just want to share your code?
fax number avatar image fax number Phong Vu ♦♦ commented ·
The fax was sending without attachments, only cover page sending.
Phong Vu answered
Sorry I did not understand the question from the title.
It is not the way to send file attachments like that. There is no boundary attached to multipart-form-data either.
Is there a reason why you have to use curl to send a fax? Using the RingCentral PHP SDK would help you simply your code and handle lots of overhead exception handlings. Look at this quick start to see how easy to send a fax using the SDK.
If you insist to use curl, let me know so I can spare some time to write it for you or read this
