sravani kandarpa avatar image
sravani kandarpa asked Anirban Sen Chowdhary answered
.Net framework 4.5 await authorize hangs
I am running below code from my console application and it works perfectly and I can fetch data
static async Task GetCallLogs() {
 var rc = new RestClient(RINGCENTRAL_CLIENT_ID, RINGCENTRAL_CLIENT_SECRET, RINGCENTRAL_PRODUCTION_URL); await rc.Authorize("username", "ext", "password");
// making api calls
But when I am doing the same thing from the .NET framework controller, system hangs at await
public void  UpdateRingCentral()
             var t= new GetCallLogs();
             t.Wait();
public async Task GetCallLogs() {
// making api calls
Any advice or suggestions for fixing this issue.
async c#
sravani kandarpa answered
Anirban Sen Chowdhary avatar image
This is a very common feature of .net platform which arise deadlock condition during making the actual REST call and parsing it as JSON .
There are many ways you can prevent this mentioned here .
Also refer here to get your answer
Another link you should read:
https://devblogs.microsoft.com/pfxteam/await-and-ui-and-deadlocks-oh-my/
There is fee more docs available on these type of issue here.
