Chandu Yela avatar image
Chandu Yela asked Rahul G answered
Phone doesn't belong to extension - Production
I have recently created app in sandbox , tested for two days and it got approved for production and i tested it using this page https://developers.ringcentral.com/api-reference/SMS/createSMSMessage
and i received the message to the number i specified
But when i tried integrating with our java application , i am getting phone doesn't belong to extension
Please help me out
smsproduction
Phong Vu avatar image
Phong Vu answered
The error message indicates that the from.phoneNumber does not belong to the extension (user) who logged in to run the app. Double check and use the direct number assigned to that user would help.
Rahul G avatar image
Rahul G answered
I think this has to do with the correct phone number, you need to ensure to use the phone number in E.164 format and also see if the post is being done as expected. Also, please share your error code what you are facing so that we can understand the issue better and help you with a resolution.
