Viresh V Pandit avatar image
Viresh V Pandit asked Eric Mann answered
Getting "InsufficientPermissions" exception
I am trying to call API /restapi/v1.0/account/accountId/extension/extensionId/fax for send fax.
But I am getting exception:
"errorCode": "InsufficientPermissions",
"message": "In order to call this API endpoint, application needs to have [Faxes] permission"
faxfax api
Anirban Sen Chowdhary avatar image
Anirban Sen Chowdhary answered
This is a permission issue happens when you call an API of an application that doesn't have that specific permission.
Check the following:
  • You are calling API of right application.
  • make sure that application you are calling have [Faxes] permission
Eric Mann avatar image
Eric Mann answered
This literally just happened to me with another application leveraging the [RingOut] permission. I'd mistakenly used an existing app in the sandbox that lacked that permission and saw the same error.
The fix is to:
  • Go into your account
  • Select the app you're trying to use
  • Click Settings in the list on the left-hand side
  • In the OAuth Settings towards the bottom, add the [Faxes] permission
  • Click Save
This worked to solve my immediate problem and might also help with yours.
