top notch avatar image
top notch asked Phong Vu commented
Forwarding call, or Ringing in the RC software phone.
I am using webhook to hook incoming call.
And created forward and reject calls based on special logic.
It works as well.
But, I don't want to reject the call.
For example, my RC phone number is +111, and I set up the forwarding number to +222.
1. The caller calls the RC number(+111). If the condition is met, it will forward to +222 (it works now).
2. Otherwise, It will be ringing in the RC software phone(+111) instead of rejecting the call (Need to be implemented). Can I forward or transfer the call to the RC number itself?
Thanks in advance.
ringcentralringoutforward call
Phong Vu avatar image
Phong Vu answered Phong Vu commented
You don't need to forward/transfer to +111 if the caller is calling that number. Just check the number (e,g. +222) you want to transfer then transfer if it matches. Otherwise, just ignore the event notification.
2 comments
top notch avatar image top notch commented ·
Thanks for your advice.
It works but I need to resolve some issues to make the forwarding call.
1. I call the RC phone number, and press 0.
2. The RC software phone is ringing first and immediately disappear.
3. And it forwards calls.
I don't want that rining the software phone first when I call the forward function.
Why the RC softphone is ringing first before forwarding?
In my opinion, via call routing
{"forwarding":{"notifyMySoftPhones":false,"notifyAdminSoftPhones":true}}
I set like this, so It doesn't appear before forwarding, but did not ring on the softphone even if i didn't forward.
PS: and Could I remove the attendant's voice message such as "press 0 to bla bla, press 1 blabla"?
Thanks in advance.
Phong Vu avatar image Phong Vu ♦♦ top notch commented ·
You can open the service web dashboard and change the setting to bypass the greeting.
