Arron Voce avatar image
Arron Voce asked Arron Voce commented
Pull call data python API
How can I pull the call data in a Python script, I've been able to connect fine however I'm not sure how to deal with pagination?
I'd like to run the script every 15 mins to pull recent calls and not create duplicats, any sample code that you can help me with?
I will then send the JSON data to a MySQL database.
call logpythonjson
Phong Vu avatar image
Phong Vu answered Arron Voce commented
Here you are. Run this script every 15 mins or put it in a loop to call every 15 mins.
from ringcentral import SDK
from credentials import *
import time, json
from time import sleep
from datetime import datetime
rcsdk = SDK( RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, RINGCENTRAL_SERVER)
platform = rcsdk.platform()
platform.login(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD)
now = time.time()
less15Mins = now - (60 * 1
dateFrom = datetime.utcfromtimestamp(less15Mins).strftime('%Y-%m-%dT%H:%M:%S.000Z'
# use the perPage to control your reading block. max is 1000 items
params = {
    'dateFrom': dateFrom,
    'perPage': 1000
resp = platform.get('/restapi/v1.0/account/~/extension/~/call-log', params)
print ((resp.json()))
run = True
while run:
    try:
        nextPage = resp.json().navigation.nextPage
        print (nextPage.uri)
        resp = platform.get(nextPage.uri)
        for record in resp.json().records:
            print ("Call type: " + record.type)
        sleep(1.2)
    except:
        print("not found")
        run = False
5 comments
Arron Voce avatar image Arron Voce commented ·
I just keep getting the error
<ringcentral.http.json_object.JsonObject object at 0x02C29DD0>
not found
[Finished in 0.877s]
Any ideas?
Phong Vu avatar image Phong Vu ♦♦ Arron Voce commented ·
Which meant that you don't have more than 1 page.
Replace the code below to see the content.
//print ((resp.json()))
print ((resp.text()))
Arron Voce avatar image Arron Voce Phong Vu ♦♦ commented ·
Thanks, I tried this and that works but only for the first page.
But when I set
dateFrom = datetime.utcfromtimestamp(less15Mins).strftime('2018-09-06T00:00:00Z')
I still get the error with resp.json and I have hundreds of pages, what am I doing wrong?
Thanks for your help :)
