PCIC Team avatar image
PCIC Team asked PCIC Team commented
System.ValueTuple error when sending/receiving fax
My application throws "Could not load file or assembly 'System.ValueTuple, Version=4.0.2.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies" whenever I try to send or retrieve a fax message. I am stumped and need help ASAP.
The interesting part is, the application runs fine on localhost. It fails when it is deployed on a server.
fax api
Phong Vu avatar image
Phong Vu answered PCIC Team commented
It seems to be a conflict in .Net Framework in your app. You may find a solution from here.
https://stackoverflow.com/questions/42867434/could-not-load-file-or-assembly-system-valuetuple/50636962
PCIC Team avatar image PCIC Team commented ·
I updated the version to 4.7.1 and new I am able use my App.
