robert-raj8062 avatar image
robert-raj8062 asked Anirban Sen Chowdhary answered
Curl restapi/oauth/token "errorCode" : "OAU-251", "message" : "Unauthorized for this grant type"
 we have try to get auth token from RingCentral auth token(/restapi/oauth/token) by using CURL call but we have get
curl -X POST "https://platform.devtest.ringcentral.com/restapi/oauth/token" -H "Accept: application/json" -H "Content-Type: application/x-www-form-urlencoded" -u "clineId:clientpassword" -d "username=username&password=password&extension=101&grant_type=password"<br>
topic-default
Tyler Liu avatar image
Tyler Liu answered
curl -i -X POST " https://platform.devtest.ringcentral.com/restapi/oauth/token"; \
-H "Accept: application/json" \
-H "Content-Type: application/x-www-form-urlencoded" \
-u "appId:appSecret" \
-d "username=username&password=password&extension=&grant_type=password"
Above is what I have tested
I think what you posted is correct. Because it is the same as mine.
Anirban Sen Chowdhary avatar image
Make sure the application you created supports Password flow since your (grant_type=password) .
Please note here, application created with different platform type will have different grant_type.
for more info, here is wonderful way it has answered with animated Gif image that will easily help you to understand the process:
https://stackoverflow.com/questions/47692828/ringcentral-auth-token-failed-in-curl-call-unauthorized-for-this-grant-type/47745436#47745436
