Tobias King avatar image
Tobias King asked Phong Vu edited
Bulk faxing app PHP
Not sure if I'm going about this the wrong way, but I'm trying to create a pretty basic bulk faxing app using PHP - open a CSV file with a list of phone numbers and send to all etc. The basic functionality of sending a fax works fine in my sandbox, but I'm struggling to find more info on what else I need to do, specifically related to rate limits and such. I should also ask if there is already an implementation of this somewhere I can just use - didn't find anything particularly useful on the RingCentral Apps or on Github.
I know there are rate limits of 10 on my 'heavy' call. Is this all faxes, or is this because I have a certain size of attachment? Either way, when I send, do I have to keep track of the limit, and once it hits 10 in 1 60 second period tell it to sleep for 59 seconds, or does the SDK do all of that and it will just continue sending when it's able to? If I do need to keep track of it, how do I get the info out of the response? In debugging, I have been able to see the info like X-Rate-Limit-Group etc, but can't figure out how to do it with code. I've tried things like $resp->_response (but _response is not available to be queried like this), $resp->getHeaders(), $resp -> getHeader('X-Rate-Limit-Limit').
$resp->json() only gives me the _jsonAsObject which does not include the _response object, so doesn't have the headers I need.
Given
$resp = $platform->sendRequest($request);
json_encode($resp);
gives me a blank array.
What am I doing wrong? Is there anything else I need to know?
Thanks in advance.
fax apirate limit
Tobias King answered
That's perfect, thanks very much.
Phong Vu avatar image
Phong Vu answered Phong Vu edited
Here you go. I give you two options, choose one of those.
<?php
require('vendor/autoload.php');
$RINGCENTRAL_CLIENTID = '';
$RINGCENTRAL_CLIENTSECRET = '';
$RINGCENTRAL_SERVER = 'https://platform.devtest.ringcentral.com';
$RINGCENTRAL_USERNAME = '';
$RINGCENTRAL_PASSWORD = '';
$RINGCENTRAL_EXTENSION = '';
$rcsdk = new RingCentral\SDK\SDK($RINGCENTRAL_CLIENTID, $RINGCENTRAL_CLIENTSECRET, $RINGCENTRAL_SERVER);
$platform = $rcsdk->platform();
$resp = $platform->login($RINGCENTRAL_USERNAME, $RINGCENTRAL_EXTENSION, $RINGCENTRAL_PASSWORD);
$listOfPhoneNumber = [
  "16501234567","16501234567","16501234567","16501234567","16501234567",
$index = 0;
//sendFaxRegularInterval();
function sendFaxRegularInterval() {
  global $rcsdk;
  global $index;
  global $listOfPhoneNumber;
  if ($index < count($listOfPhoneNumber)){
    $request = $rcsdk->createMultipartBuilder()
                     ->setBody(array(
                         'to' => array(array('phoneNumber' => $listOfPhoneNumber[$index])),
                         'faxResolution' => 'High',
                     ->add(fopen('test.jpg', 'r'))
                     ->request('/account/~/extension/~/fax');
    $resp = $rcsdk->platform()->sendRequest($request);
    print_r ("FAX sent. Message status: " . $resp->json()->messageStatus."\n");
    $jsonObj = $resp->response();
    $limit = strval($jsonObj->getHeaders()['X-Rate-Limit-Limit'][0]);
    $limitRemaining = strval($jsonObj->getHeaders()['X-Rate-Limit-Remaining'][0]);
    $limitWindow = strval($jsonObj->getHeaders()['X-Rate-Limit-Window'][0]);
    $delayInterval = 0;
    if ($limitRemaining == 0){
        print_r("no remaining. panelty\n");
        $delayInterval = ($limitWindow / $limit);
    }else{
        $delayInterval = ($limitWindow / $limitRemaining);
    sleep($delayInterval);
    $index++;
  }else{
    print_("Done\n");
$startTime = time();
sendFaxAsFastAsPossible();
function sendFaxAsFastAsPossible() {
  global $rcsdk;
  global $startTime;
  global $index;
                       ->setBody(array(
      $delayInterval = 0;
          print_r("no remaining. wait for next window\n");
          $now = time();
          $diff = $now - $startTime;
          $delayInterval = ($limitWindow - $diff);
          $startTime = $now + $delayInterval;
      $index++;
  }else{
      print_r("Done\n");
Hope this helps!
