Samir Patel avatar image
Samir Patel asked Phong Vu commented
ringcentral java sdk RestClient authorize throws null pointer exception
Running following code on tomcat throws null pointer exception. Running same code in java main method runs fine.
        RestClient rc = new RestClient(clientID, clientSecret, serverURL);
        System.out.println("server-> " + rc.server);
        try {
            rc.authorize(username, extension, password);
            GetVersionsResponse result = rc.restapi().list();
            System.out.println("Result " + result.uri);
            rc.revoke();
        catch (IOException e) {
            // TODO Auto-generated catch block
            e.printStackTrace();
        catch (RestException e) {
java.lang.NullPointerException
at com.ringcentral.RestClient.requestRaw(RestClient.java:257)
at com.ringcentral.RestClient.request(RestClient.java:320)
at com.ringcentral.RestClient.request(RestClient.java:251)
at com.ringcentral.RestClient.post(RestClient.java:146)
at com.ringcentral.paths.restapi.oauth.token.Index.post(Index.kt:18)
at com.ringcentral.RestClient.authorize(RestClient.java:113)
ringcentral java sdk restclient authorize throws null pointer exception
Khadhar Koneti avatar image
Khadhar Koneti answered Samir Patel commented
HI, Ideally you should not get the null pointer. How you are loading ring central dependencies ? If you are using maven or gradle then try to use latest version jars.
2 comments
Samir Patel avatar image Samir Patel commented ·
Can your share list of dependencies for java server project?
Samir Patel avatar image Samir Patel Samir Patel commented ·
Sorry thanks for your input. I figured out.
Phong Vu avatar image
Phong Vu answered Phong Vu commented
It looks like something is wrong in your project settings that did not import the RingCentral SDK properly. I don't see this line printed in your post:
Can you double check or show how you import the SDK?
2 comments
Thank you. Let me give try again. The server line is printed, fails on authorize call
server-> "https://platform.devtest.ringcentral.com"
Phong Vu avatar image Phong Vu ♦♦ Samir Patel commented ·
Have you put some breakpoints and run line by line to see what object is null? Also which catch did it end up in
Samir Patel answered
