Rick Smith avatar image
Rick Smith asked Rick Smith answered
Gettting Failed to install 'ringcentral_client==0.6.0' in Python 3.7
Hello all
Have the following code its Python 3.7 When I try to import ring_central client I get Any ideas?
----- Failed to install 'ringcentral_client==0.6.0' -----
The code I have so far...
import time
import json
import os
from ringcentral_client import PubNub
from ringcentral import SDK
from ringcentral_client import RestClient, SANDBOX_SERVER
#DO NOT MODIFY ANY OF THIS OR IT WILL BLOW UP IN YOUR FACE
rc= RestClient("blahbla", "other","https://platform.devtest.ringcentral.com")
rc.authorize('+1XXXXXXX, ''', 'mypasword')
ringout_body = {
"to": {"phoneNumber": 'number'},
"from": {"phoneNumber": 'othernumber'},
"callerId": {"phoneNumber": 'id'},
"playPrompt": "true"
response = rc.post('/restapi/v1.0/account/~/extension/~/ring-out',ringout_body)
python ring_central client
Phong Vu avatar image
Phong Vu answered
Where do you get the ringcentral_client? Is that your own lib?
To use the RingCentral Python SDK, here is all you need to do:
rcsdk = SDK( "CLIENTID", "CLIENTSECRET", "RINGCENTRAL_SERVER_URL")
platform = rcsdk.platform()
platform.login("USERNAME", "EXTENSION", "PASSWORD")
resp = platform.post('/restapi/v1.0/account/~/extension/~/ring-out',
                  'from' : { 'phoneNumber': 'othernumber' },
                  'to'   : {'phoneNumber': 'number' },
                  'callerId': {'phoneNumber': 'id'},
                  'playPrompt' : False
print "Call placed. Call status: " + resp.json().status.callStatus
Rick Smith answered
Thanks!
I believe it came from Ring Central, It's older code so I'm not sure.
Anyway I will try as you suggest.
Thanks Again
Rick Smith answered Phong Vu commented
Ok, I tried the code and I am getting
Invalid resource owner credentials
I believe it's a phone number that's the user name at least tha's what I had before, or it could be the password...Not sure.
at
  • platform.login("USERNAME", "EXTENSION", "PASSWORD")
Phong Vu avatar image Phong Vu ♦♦ commented ·
You just need to double check the user name and password are correct. Remember the credentials for sandbox are different for the one for production if you happen to test it on your production environment.
Rick Smith answered Rick Smith commented
Thanks,
I checked as far as I can tell, it's correct, now it's throwing "unauthorized for this grant type" at platform.login. I tried enabling every type of grant??? I could still nothing....
4 comments
What is the app's auth type? password flow? Or let me know your app client id.
Rick Smith avatar image Rick Smith Phong Vu ♦♦ commented ·
Phong, thanks here is the client ID
dKXy39MFTI200gzNYa4vLg
not sure about auth type, where di I set that? and password flow, not sure on that either? what is it?
Phong Vu avatar image Phong Vu ♦♦ Rick Smith commented ·
Ok, your app scope is "Public" and the platform type is "Desktop/Windows". That's why you cannot use password flow login. Please read this dev guide for more info about authentication/authorization.
I am not sure about the purpose of your app and why you chose it as "Public" so I cannot help you change the scope to "Private" which allows me also change the platform type to support password flow authentication.
You can either create a new app, set the scope to "Private" and the server type to "Server-only/(No UI)" then you can use password flow authentication. Or implement 3-legged authentication to login. Or let me know if this app can be a private app so I can help to change them for you.
Rick Smith answered
Hello All:
Still unable to get the ringout code to work, has anybody gotten it to work in python or C#?, However, I did get SMS to work and was able to send a text message as an experiment.
My real goal is to be able to receive or read and an incoming call and then perform various actions...Is this possible? I am fairly certain I can do this with SMS, but not to clear on voice?
Thanks for any help
