Pramod Kangare avatar image
Pramod Kangare asked Phong Vu answered
Getting stuck at Authorize method.
The control is getting stuck in this line "restClient.Authorize(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD).Wait()". We have provided all the valid inputs but still the control is not moving to next line.
authorizationauthentication
3 comments
Phong Vu avatar image Phong Vu ♦♦ commented ·
The code works well for others so it must be something is different in your environment.
I can't help if you don't provide enough information about your app setup, your .Net environment etc.
Pramod Kangare avatar image Pramod Kangare Phong Vu ♦♦ commented ·
It is implemented in mvc web application using C# .
Platform type is 'Server/Web' in AppType & PlatformType
Phong Vu answered
The code you are showing is for password flow authentication and it works with "Server-only (No UI)" app type. Since your app type is "Server/Web" which require authorization flow authentication. If you really need your app is a "Server/Web" app, then follow the instructions from this developer guide to implement your app. If the app type supposed to be "Server-only", then either you create a new app with the correct app type. Or let me know your current app client id so I can change it for you.
