Rick Smith avatar image
Rick Smith asked Rick Smith answered
ModuleNotFound Error with ringcentral 0.7.11
I am getting the following error
from ringcentral import sdk
ModuleNotFoundError: No module named 'ringcentral'
However when I check I appear to have it installed (ringcentral(0.7.11) and Python 3.7 64bit on Win 10
The code I have oddly enough runs fine in my dev environment(VS 2019) perfectl tried installing ringcentral_client 0.60 this fails to install
python ring_central client
Rick Smith answered
Anirban,
Thanks Much! I got it figured out, Looks like it was the Visual C++ Build tools that where missing, downloaded those, re-installed the SDK(using pip install not the stuff VS provides) and it worked)
Anirban Sen Chowdhary avatar image
Anirban Sen Chowdhary answered Anirban Sen Chowdhary edited
Is RingCentral Python SDK installed correctly?
Can you pls check following links... steps are given to resolve:
https://github.com/ringcentral/ringcentral-glip-errbot/issues/1
Also another reference here:
https://forums.developers.ringcentral.com/questions/7978/ringcentral-import-error-in-python.html
Rick Smith answered
Anirban,
Thanks, It is not doing anything after I do the config.py step?
It just displays
config.py[+] [unix] (18:59 31/12/1969)
-- insert --
Entering the rest of the data appears to do nothing??
