I'm using the latest official C# SDK in a new
ASP.NET Core 2.0 web application. Although the SDK isn't built to the same target framework, the app compiles and seems ok. I've tried just about every setting (public/private, web, web/ui, etc.) but I always get the following error:
FlurlHttpException: Request to https://platform.devtest.ringcentral.com/restapi/oauth/token failed with status code 400 (Bad Request).
I'm using simple code which appears the same as the SDK sample:
var restClient = new RestClient(appKey, appSecret, appUri);
await restClient.Authorize(userName, extension, password);
If you're able to look up my account info to verify, the sandbox values I'm using are:
Any help is greatly appreciated, I've scoured the community forum and the web. It seems that this error is generally from people not using the sandbox credentials, or the wrong password, but I've changed the sandbox password a zillion times, to no avail.
Thank you!
- appKey = f6v********-61******kw
- appSecret = JR****u_QG**************TxA
- appURI = https://platform.devetest.ringcentral.com
- userName = +1313*****01
- extension = 101
- password = 1rc********st!
Thank you!
