Chady Boutros avatar image
Chady Boutros asked Phong Vu commented
Errors when trying to put a call on hold
When i try to put an answered call from our external 'Yealink' phone on hold i get an error in guzzle.
this is what my api call looks like and i am logged into the platform as all my other calls are working. Im using this https://developers.ringcentral.com/api-reference/Call-Control/holdCallParty as my reference and was also confused as to why this call never needed the extension. Ive tried the call with both the account and extension and got the same error.
And The Errors I am getting when running this. Also keep in mind we have successfully recieved the incoming webhook call and i store the telephonySessionId. Also I have implemented delete call session and this is successful ==> https://developers.ringcentral.com/api-reference/Call-Control/deleteCallSession
I Underlined the strange things that popped out to me. Almost looks like it's not swapping in the accountId.
Thanks For your help.
apicall controltelephony
Phong Vu avatar image
Phong Vu answered
Add the "/" to the beginning of your $path
$path = '/account/~/telephony ...'
Chady Boutros answered Phong Vu commented
I implemented that solution, but it made no difference. The outside phone does not respond. I can't answer, or hold. Am I doing this wrong?
Phong Vu avatar image Phong Vu ♦♦ commented ·
What do you mean no difference? Does it still crash with the exception above?
Yes same error as above, here is the same exception being thrown. I printed out the path being used from the post call too. The overall exception is being thrown from guzzle and not ringcentral.
Here is the php code calling site as well.
Thank you, any help is greatly appreciated.
So i dug deeper and put some logs in the ringcentral Client.php, here they are.
When i run this code i get this for the output.
The Constructor for a GuzzleHttp Request does not take an array for the body.
eventually this array ends up here and this is where the exception is thrown.
Im going to try checking ahead of time if its an array and just pass in an empty string.
Thanks for your time.
I threw this in there just to make the call work and ended up with a valid error from the ringcentral api
Now im stuck with this.
:D fun times.
Phong Vu answered Chady Boutros commented
Now I pay closer attention to your first code sample, why do you pass an empty array to the post request that does not take any body?
Simply remove it.
$path = "/account/accountId/telephony/sessions/[telephonySessionId]/parties/[partyId]/hold";
  try{
      $resp = $platform->post($path);
  }catch (ApiException $ex){
      print_r("error");
      print_r($ex->getMessage());
3 comments
Chady Boutros avatar image Chady Boutros commented ·
Thank you for the response. Sometimes, even if I remove that array, I'm still getting that device state error from ring central. Is there anywhere you can point me for this type of error?
Phong Vu avatar image Phong Vu ♦♦ Chady Boutros commented ·
You got to tell me what works what does not work. There are many reasons why it returns errors. If removing the empty array works for you, you should confirm that so I would know what's next.
Now, "sometimes" does not help me to diagnose and help you. All in all, the endpoint is very straightforward with just the valid telephonySessionId and the partyId.
Chady Boutros avatar image Chady Boutros Phong Vu ♦♦ commented ·
I answered your question below. The error code is TAS-102, and it says Incorrect State. I just can't figure this out. I appreciate all your help very much.
Hi, i can confirm that removing the empty array did work for us. Now we are just stuck on the device error.
thank you for your time.
This is a different problem. You should be clear in your answer if the first problem was solved then I could help you faster rather than going back an forth.
With the "Incorrect State error message, it is either the partyId is incorrect (maybe the partiId is of the "customer") or the call is not yet connected. To identify the problem, make sure the call is connected, and also print out all the party ids from that call and try with other party ids.
