Lior Gerson avatar image
Lior Gerson asked Lior Gerson commented
JavaScript (Node) - How do i get messageStore list using multiple message types?
I'm using ringcentral-ts in my node application.
Trying to get messageStore for SMS and VoiceMail only by ringCentral.account().extension(extentionId).messageStore().list(params)
In params, there is a property called messageType which defined as:
* The type of the resulting messages. If not specified, all messages without message type filtering are returned. Multiple values are accepted
messageType?: 'Fax' | 'SMS' | 'VoiceMail' | 'Pager' | 'Text';
My question is how do i actually query for multiple types?
(There is a compilation error if i'm trying to put multiple values for messageType)
Thanks!
message-storenodets
Phong Vu avatar image
Phong Vu answered
Simply put them in an array ["Fax", "SMS"] etc.
Lior Gerson answered Lior Gerson commented
Phong, thanks for your reply.
Unfortunately i can't use an array because of messageType definition:
2 comments
Phong Vu avatar image Phong Vu ♦♦ commented ·
What SDK and language are you using? Looks like Java but not sure if you are using our SDK.
If you are using our SDK, here is the way to create the params
ListMessagesParameters parameters = new ListMessagesParameters();
parameters.messageType = new String[] {"VoiceMail", "Fax", "SMS};
Lior Gerson avatar image Lior Gerson Phong Vu ♦♦ commented ·
I'm using RingCentral for Typescript - https://github.com/zengfenfei/ringcentral-ts/
