vb avatar image
vb posted Byrne Reese edited
Why does OAuth return "unauthorized for this grant type" error?
Are you receiving the following error when you call the /oauth/token API to authorize your application?
"error": "unauthorized_client"
"error_description": "Unauthorized for this grant type"
To fix this problem, check the following:
Is your "application type" ==> "Web/UI based" or "browser-based application?"
If the answer is yes you will need to follow the 3 legged OAuth flow to authorize your application.
The authorization code flow provides the following benefits:
  • a consistent and trusted UI
  • integrated password reset
  • integrated single sign-on (SSO) via SAML support
For more information please check out the following:
topic-default
6 comments
1 |1000
duane-smith1885 avatar image duane-smith1885 commented ·
I'm also getting this exact same error using Advanced REST client and vb.net desktop application.
ak avatar image ak commented ·
Hi Duane,
Could you please check the application type, login to the developer portal (  https://developer.ringcentral.com ) and click on the application and under settings you should see the "Platform Type" . If the platform type is any one of below :
  • Browser-Based
  • Server-Web
  • Server-Only
Then you would need to follow the OAuth 2.0 Code flow for authentication. You could find more information and sample codes here :  https://devcommunity.ringcentral.com/ringcentraldev/topics/using-oauth-2-0-authorization-code-grant-...
chris-dierdorff5904 avatar image chris-dierdorff5904 ak commented ·
the information here is telling us what OAuth 2.0 is, not how to use it. Are there any resources that help new developers actually USE this auth type?
It's a vb.net desktop application. In Platform Type I have Desktop/Windows.
I'm using  Resource Owner Password Credentials Flow (ROPC), also named  Password Flow.
Using the SDK c# code tests from RingCentral, it works fine. However, running very similar .net 2.0 code it doesn't. Also, running the RingCentral API Explorer and Advanced REST client doesn't work. Here's the code I'm using:
        Dim client As New WebClient()
        Dim parameters As String = "grant_type=password" &
                                   "&username=15623520324" &
                                   "&extension=101" &
                                   "&password=" & password
        Dim URL As String = GetUrl("restapi/oauth/token")
        client.Headers.Add(HttpRequestHeader.ContentType, "application/x-www-form-urlencoded;charset=UTF-8")
        client.Headers.Add(HttpRequestHeader.Authorization, "Basic " & GetApiKey())
        Dim result As String = client.UploadString(URL, "POST", System.Web.HttpUtility.UrlEncode(parameters))
        Assert.NotNull(result)
        Return result
zeeshan-yousaf2030 avatar image zeeshan-yousaf2030 commented ·
Hi, i m trying to use JS Liberary  but getting same error. if some one could guide it would be great help my code as below:
$(document).ready(function() {
 var RC_SERVER_PRODUCTION = ' https://platform.ringcentral.com';
 var RC_SERVER_SANDBOX = ' https://platform.devtest.ringcentral.com';
 //var RC_SERVER_SAOX = ' https://service.devtest.ringcentral.co.uk';
 var rcsdk = new RingCentral.SDK({
  server : RC_SERVER_SANDBOX,
  appKey : 'GXXXXXXXXXXXXXX',
  appSecret : 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'
 var platform = rcsdk.platform();
 rcsdk.platform()
    .login({
        username: '+4420377136XX', // phone number in full format which is given under sandbox credentials
        extension: '301', // Admin default
        password: 'XXXXXXXXXXXXX' // Here my ringcentral developer account password
    .then(function(response) {
          // your code here
          console.log(response);
    .catch(function(e) {
        alert(e.message  + 'Server cannot authorize user');
cfhe-reception1779 avatar image cfhe-reception1779 commented ·
The following works fine for me. Maybe it will help.
Public Const RingCentralTokenURI = " https://platform.ringcentral.com/restapi/oauth/token "
Public Const LoginUserName = "%2B18185555555"
Public Const LoginPassword = "mypassword"
Dim httpRequest As New MSXML2.XMLHTTP
Dim PayLoad As String
PayLoad = "grant_type=password&username=" & LoginUserName & "&extension=119&" & "password=" & LoginPassword
httpRequest.Open "POST", RingCentralTokenURI, False
httpRequest.setRequestHeader "Authorization", "Basic xxxxxxxxxxxxxxxxxxx"    httpRequest.setRequestHeader "Content-Type", "application/x-www-form-urlencoded;charset=UTF-8"
httpRequest.Send PayLoad
Access_Token = "Bearer " & Mid(Mid(httpRequest.responseText, InStr(1, httpRequest.responseText, """access_token"" : """) + 18), _
        1, InStr(1, Mid(httpRequest.responseText, InStr(1, httpRequest.responseText, """access_token"" : """) + 18), """,") - 1)
 Debug.Print Access_Token
ByrneReese contributed to this article vb contributed to this article
