James Walker avatar image
James Walker asked Phong Vu commented
Auth Flow ERR_CONNECTION_REFUSED on localhost
Hi. I am trying to run the Authorization Flow demo.
After I enter my username and password, I get a connection refused error. The uri in the browser looks like the following:
http://localhost:5000/oauth2callback?code=U0pDMTFQM
with a long string for code.
Any hints as to where to go next?
auth code flow
Phong Vu avatar image
Phong Vu answered
Can you show how you implement your code? Take out sensitive information such as you app client id, secret etc.
James Walker answered arjun singh commented
I just copied the C# example from the ringcentral site. The only thing I changed was the Client ID and Secret:
using System.Linq;
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Hosting;
using Microsoft.AspNetCore.Http;
using Microsoft.Extensions.DependencyInjection;
using RingCentral;
using Newtonsoft.Json;
using Microsoft.Extensions.Hosting;
namespace RCAuthFlowV2
public class Startup
private const string RINGCENTRAL_CLIENT_ID = "XXXXXXXXXX";
private const string RINGCENTRAL_CLIENT_SECRET = "YYYYYYYYYYYYYYYYYYY";
private const string RINGCENTRAL_SERVER_URL = "https://platform.devtest.ringcentral.com";
private const string RINGCENTRAL_REDIRECT_URL = "http://localhost:5000/oauth2callback";
private const string SESSION_TOKEN_KEY = "rc-token";
public void ConfigureServices(IServiceCollection services)
services.AddMvc().AddSessionStateTempDataProvider();
services.AddSession();
private static string Html(string body)
return $@"<!doctype html><html><body>{body}</body></html>";
public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
if (env.IsDevelopment()) app.UseDeveloperExceptionPage();
app.UseSession();
app.Run(async (context) =>
var rc = new RestClient(RINGCENTRAL_CLIENT_ID, RINGCENTRAL_CLIENT_SECRET, RINGCENTRAL_SERVER_URL);
var tokenString = context.Session.GetString(SESSION_TOKEN_KEY);
if (tokenString != null)
rc.token = JsonConvert.DeserializeObject<TokenInfo>(tokenString);
else if (context.Request.Path != "/oauth2callback")
var oauthUri = rc.AuthorizeUri(RINGCENTRAL_REDIRECT_URL);
await context.Response.WriteAsync(
Html($"<h2>RingCentral Authorization Code Flow Authentication</h2><a href=\"{oauthUri}\">Login RingCentral Account</a>"));
return;
switch (context.Request.Path)
case "/":
await context.Response.WriteAsync(Html(@"<b><a href=""/logout"">Logout</a></b>
<h2>Call APIs</h2>
<ul>
<li><a href=""/test?api=extension"" target=""_blank"">Read Extension Info</a></li>
<li><a href=""/test?api=extension-call-log"" target=""_blank"">Read Extension Call Log</a></li>
<li><a href=""/test?api=account-call-log"" target=""_blank"">Read Account Call Log</a></li>
</ul>"));
break;
case "/oauth2callback":
context.Request.Query.TryGetValue("code", out var codes);
var code = codes.First();
await rc.Authorize(code, RINGCENTRAL_REDIRECT_URL);
context.Session.SetString(SESSION_TOKEN_KEY, JsonConvert.SerializeObject(rc.token));
context.Response.Redirect("/");
break;
case "/test":
context.Request.Query.TryGetValue("api", out var apis);
var api = apis.First();
var result = "";
switch (api)
case "extension":
result = await rc.Get<string>("/restapi/v1.0/account/~/extension");
break;
case "extension-call-log":
result = await rc.Get<string>("/restapi/v1.0/account/~/extension/~/call-log");
break;
case "account-call-log":
result = await rc.Get<string>("/restapi/v1.0/account/~/call-log");
break;
await context.Response.WriteAsync(Html($"<pre>{result}</pre>"));
break;
case "/logout":
await rc.Revoke();
context.Session.Remove(SESSION_TOKEN_KEY);
break;
default:
context.Response.StatusCode = 404;
break;
Phong Vu avatar image Phong Vu ♦♦ commented ·
First of all, you post nothing, then you post the entire code copied from a document. Next time, just some part if it's your own code or refer to the code if it's our. And post in within the code block </>.
I am not sure how and why you end up in receiving it. It should be coming to this block where we send the "code" to exchange for an access token.
    break;
Can you put a few breakpoints to your code and run to see if it reach the block above?
