Customer Service avatar image
Customer Service asked Phong Vu edited
CURL Update Crashed Api
A client's custom API stopped working last night after a curl update. Our server admins were able to roll back the update and everything worked just fine again. But, they indicate the update is going to be downloaded again - so, what can be done to make sure the RingCenteral PHP SDK continues to work? It was installed using COMPOSER.
This is package that crashed the API:
Command Line : -y install ea-libcurl-7.79.1-2.2.3.cpanel.x86_64.rpm
Transaction performed with:
Installed rpm-4.8.0-59.el6.x86_64 @base
Installed yum-3.2.29-81.el6.centos.0.1.noarch @updates
Installed yum-plugin-fastestmirror-1.1.30-42.el6_10.noarch @updates
Packages Altered:
Updated ea-libcurl-7.69.1-2.2.3.cpanel.x86_64 @EA4
Update 7.79.1-2.2.3.cpanel.x86_64 @/ea-libcurl-7.79.1-2.2.3.cpanel.x86_64
fax api
2 comments
Customer Service avatar image Customer Service commented ·
This is the error from the log before we rolled-back the CURL update from last night:
[17-Apr-2020 13:03:45 UTC] PHP Fatal error: Uncaught GuzzleHttp\Exception\RequestException: cURL error 3: (see http://curl.haxx.se/libcurl/c/libcurl-errors.html) in /home/***CLIENTDIR***/sdk-php-rcentral/vendor/guzzlehttp/guzzle/src/Handler/CurlFactory.php:186
Stack trace:
#0 /home/***CLIENTDIR***/sdk-php-rcentral/vendor/guzzlehttp/guzzle/src/Handler/CurlFactory.php(149): GuzzleHttp\Handler\CurlFactory::createRejection(Object(GuzzleHttp\Handler\EasyHandle), Array)
#1 /home/***CLIENTDIR***/sdk-php-rcentral/vendor/guzzlehttp/guzzle/src/Handler/CurlFactory.php(102): GuzzleHttp\Handler\CurlFactory::finishError(Object(GuzzleHttp\Handler\CurlHandler), Object(GuzzleHttp\Handler\EasyHandle), Object(GuzzleHttp\Handler\CurlFactory))
(continued)
(continued)
#2 /home/***CLIENTDIR***/sdk-php-rcentral/vendor/guzzlehttp/guzzle/src/Handler/CurlHandler.php(43): GuzzleHttp\Handler\CurlFactory::finish(Object(GuzzleHttp\Handler\CurlHandler), Object(GuzzleHttp\Handler\EasyHandle), Object(GuzzleHttp\Handler\CurlFactory))
#3 /home/***CLIENTDIR***/sdk-php-rcentral/vendor/guzzlehttp/guzzle/src/Handl in /home/***CLIENTDIR***/sdk-php-rcentral/vendor/ringcentral/ringcentral-php/src/Http/Client.php on line 52
Phong Vu avatar image
Phong Vu answered Phong Vu edited
Can you check you dependencies based on the SDK requirements https://github.com/ringcentral/ringcentral-php/blob/master/composer.json
