I am learning puppet but I stuck with one problem. I have a Puppet installation with one Puppet master and one Puppet agent, and I am using open source Puppet. I to set up a environment named Test. The directory is as follows /etc/puppet/environments/Test
its having modules
and manifests
directories. And environment.conf
file.
My environment.conf
contains the following line:
modulepath = $confdir/environments/production/modules
I created a module named sample
inside the modules
directory of the environment. Described one class called sample
inside the init.pp
of the sample
module's manifests
directory. The class is used to install a small puppet software. In the the manifests
directory of the environment Test I created a file site.pp
which will implement the class sample
defined inside the module.
My puppet.conf
contains this following lines:
[main] logdir=/var/log/puppet vardir=/var/lib/puppet ssldir=/var/lib/puppet/ssl rundir=/var/run/puppet factpath=$vardir/lib/facter prerun_command=/etc/puppet/etckeeper-commit-pre postrun_command=/etc/puppet/etckeeper-commit-post server=puppet.master
[master] ssl_client_header = SSL_CLIENT_S_DN ssl_client_verify_header = SSL_CLIENT_VERIFY
site.pp
and not using the environments
site.pp
