Tanmay Kumar avatar image
Tanmay Kumar asked Anirban Sen Chowdhary answered
How to remove refresh token from oauth call
I am able to generate oauth tokens from the url https://platform.devtest.ringcentral.com/restapi/oauth/token successfully.
However I can see both refresh token and access token is generated in the call.
Can we remove the refresh token during the oauth call so that only access token is generated.
I have seen this feature of suppressing and disabling refresh token in other oauth servers.
Does it apply in ringcentral too?
oauth2
Anirban Sen Chowdhary avatar image
Yes, refresh tokens can be disabled by setting the TTL (time to live) for the refresh_token_ttl to zero
example:
username=<username>&password=<password>&extension=<extension>&grant_type=password&refresh_token_ttl=0
refresh_token_ttl=0
